  3. Sistem electric
  • scanx
  • Mesaje scrise: 681
  • Masina: Corsa 2001 Z12XE
  • Cont inregistrat: 07 Jun 2009
ECU comanda acel releu. Clar nu s-a facut ce-am scris eu mai sus, ca altfel erai finalizat de mult.
  • rlucian_23
  • Mesaje scrise: 16
  • Masina: Corsa 2008 Z13DTJ
  • Cont inregistrat: 17 Oct 2011
Se repara ECU de corsa D 1.3 cdti motor Z13DTJ? Am vazut multe alte modele care se repara ...presupun ca si asta. O sa contactez colegul de forum de la ecu.ro poate se baga si la modelul asta.
Multumesc
  • calugaru23
  • Masina: Vectra 2001 Z16XE
  • Cont inregistrat: 16 Aug 2012
salut!am urmatoarea problema
am un vectra b 2001 si de aprox 2 luni cand o turez mi se aprinde martorul de la motor in bord si merge parca e inecata.se aceleraza foarte greu si nu trage.am pus.o pe tezter si m.i s.a spus ca e calculatorul in proportie de 75% ma puteti ajuta cumva?calc asta se poate repara?
  • Atex
  • Mesaje scrise: 143
  • Cont inregistrat: 21 Feb 2010
Este reparabila,ce eroare ai avut pe tester?
  • calugaru23
eroarea aparuta este mised fire si am probat bobina de inductie si este functionala
  • big_electro61
  • Mesaje scrise: 4,492
  • Masina: Astra 2008 Z13DTH
Cred ca nu are nimic calculatorul tau.Uite citeva cauze posibile aici: Cylinder 1 Misfire Detected
What does this mean?
OBD Code P0301refers to
A P0301 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #1.
Symptoms
Possible sumptoms of OBD code P0301
the engine may be harder to start the engine may stumble / stumble, and/or hesitate other symptoms may also be present
Causes
Possible causes of OBD code P0301
A code P0301 may mean that one or more of the following has happened: Faulty spark plug or wire Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector Burned exhaust valve Faulty catalytic converter(s) Running out of fuel Poor compression Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors. De regula e bine sa scrii codul de eroare exact(P-xxxx),pentru a sti ce discutam,poate fi vorba de un anumit cilindru,sau de o multitudine de cilindri.
  • nicustoica
  • Mesaje scrise: 31
  • Masina: Astra 2001 Y17DT
  • Cont inregistrat: 07 Sep 2012
Catre, 1.7 dti_edition2000 bucuresti si dancuciureanu din iasi, am deschis un topic OPEL ASTRA 1.7 dti nu se accelereaza va rog frumos uitati-va la el si dati-va cu parerea .
  • Mesaje scrise: 16,465
Cumpara alt ECU
  • nicustoica
  • Mesaje scrise: 31
dupa ce montez ecu ,immo si cip mai trebuie ceva rezolvat ca sa mearga acceleratia?
Mai simplu e sa cumperi un ECU resetat si numai il programezi pe masina, evident trebuie cod securitate la a ta. Daca schimbi ECU+IMO+cip nu vei sti ce cod securitate vei avea, in rest nu trebuie nimic de setat.
  • nelutzul40
  • Mesaje scrise: 1,009
  • Cont inregistrat: 24 Feb 2008
Mi-a cedat si mie calc injectie, simptomele binecunoscute, oprit in mers si pornire dupa ceva timp. Am citit cam tot ce e scris aici, mi-am luat inima in dinti si am facut singur ,,operatia,, de resuscitare, rezultat: ,,client,, viu!
Multumesc frumos club opel si membrilor sai!
  • big_electro61
In ce consta procedura de "resuscitare" a calculatorului de injectie...?
  • vali zak
  • Mesaje scrise: 378
  • Masina: Astra 2004 Y20DTH
  • Cont inregistrat: 26 Nov 2005
Cine mai repara ecu pentru z16xe in Bucuresti in afara de Mihai care nu raspunde la telefon?
Masina porneste bine la rece,in momentul in care se incalzeste se opreste si stocheaza eroarea P 0230...se pare ca vinovat e ECU,ceva lipitura rece la pinul 23...Cineva pe forum spunea de o masa suplimentara la releu care sa faca pompa sa functioneze pana ajung cu ea la mecanic...va rog sa ma ajutati cu ceva sfaturi .Merci.
  • gogosica
  • Mesaje scrise: 209
  • Masina: Zafira 2001 Z18XE
  • Cont inregistrat: 15 Jul 2011
si eu am aceleasi simptome
numai ca am o zafira de 1,8 motor Z18XE
tot la fel trebuie sa î-l trimit la cineva, dar nu e din Bucureºti
de fapt abia am descoperit
  • big_electro61
vali zak a scris:Cine mai repara ecu pentru z16xe in Bucuresti in afara de Mihai care nu raspunde la telefon?
Releele K20(electopompa+injectoare) si K46(ECM),au ambele comanda pe -(minus),iar o punte(sunt de 0,5mm2) intre cele doua relee a rezolvat problema pe moment,iar daca nu te deranjeaza poate ramine definitiv.
  • dyass
  • Mesaje scrise: 30
  • Masina: Vectra 2001 zx18xe
  • Cont inregistrat: 04 Aug 2008
sall ajutati-ma si pe mine stiam de corsa aceea ca nu vrea sa porneasca si au reusit cu alt ecu dar masian mea vectra b z18xe e tot la maiandrei si de 3 luni nu ii dau de cap....simptome...:porneste se opreste dupa 3 secunde si da eroare de immo....ce s afac.....au zis sa incercam cu alt ecu au incercat si nu vrea.....acum caut un ecu si immo si cip programate deja ma poate ajuta cineva daca nu gasesc baietii.....ce sa fac nu vrea de niciun fel.....toata recunostinat baietilor sse tin de treaba dar nu mai exista solutii....ma poate ajuta cineva sa imi dea un sfat cv?
multam......
  • nicustoica
  • Mesaje scrise: 31
Am facut comanda de ecu imo si cip , le montez si gata , sa vedem functioneaza? Samsata nu a mai vrut sa porneasca.
  • dyass
  • Mesaje scrise: 30
nicostoica nu am inteles ce ai scris in ultima fraza......esti de la service de la maiandrei?sper sa mearga DOAMNE AJUTA!
  • mihaiadrian
  • Mesaje scrise: 629
  • Masina: Vectra 2001 z16xe
  • Cont inregistrat: 26 Aug 2010
Ecu ul care il cumperi trebuie sa fie compatibil si sa fie de pe acelasi tip de masina/motorizare ca a ta. Altfel, necesita reprogramare si zici mersi daca din 4 chei iti porneste odata si poti sa duci masina la programare ca sa nu chemi platforma. Apoi, ecu ul tre sa fie resetat sau sa ai cod securitate la el ca sa poti sa il imperechezi cu imobilizatorul. Eu am trecut odata prin asta, noroc ca am gasit pe cineva priceput care mi l a reprogramat.
Dupa schimbare s a rezolvat problema cu pedala acceleratie, p1530, p0230 partial, temp exterioara.
  • nicustoica
  • Mesaje scrise: 31
Vezi topic OPEL ASTRA 17 dti nu se accelereaza .Ce este BCM ? Trebuie schimbat si bcm sa porneasca,am montat ecu si maine montez imo si cip pot sa pornesc?Dati-mi ceva sfaturi. Mi-a spus ca ecu ,imo si cip sunt de la acelasi model de masina ca a mea .
  3. Sistem electric
