  2. Tutoriale
  3. Mic dicționar explicativ
  • dantes975
  • Mesaje scrise: 11
  • Masina: Astra 2000 y17dt
  • Cont inregistrat: 18 Oct 2005
ce este imobilizer si ce rol are?
  • love4cars
  • Mesaje scrise: 1,437
  • Masina: Astra Z14XEP
  • Cont inregistrat: 24 Sep 2005
un device electronic cu ajutorul caruia masina este invulnerabila la furt.
  • roBERT
  • Mesaje scrise: 1,724
  • Masina: Astra 2002 Z20LET
... un dispozitiv care citeste/identifica un microchip "lipit" pe cheia ce contact a masinii, in acest fel se elimina posibilitatea fortarii butucului si implicit a furtului...
  • b82bog
  • Mesaje scrise: 400
  • Masina: Astra Y17DT
  • Cont inregistrat: 19 Sep 2005
Daca cineva face o dublura dupa cheie masina nu va porni 😊
  • pufulet
  • Mesaje scrise: 303
  • Masina: Astra 2006 Z16XEP
  • Cont inregistrat: 03 Feb 2006
microcipul e microscopic? ca ma uit pe cheie si nu vad nimic
  • b82bog
Nu e microscopic 😂 E adevarat ca nu este f mare dar se afla in interiorul carcasei cheii (cel putin la mine)
  • zafirul
  • Mesaje scrise: 1,442
  • Masina: Zafira 2001 Z18XE
  • Cont inregistrat: 22 Apr 2004
nu confundati cipul din cheie.... 😂
An immobiliser is an electronic device fitted to an automobile which prevents the engine from running unless the correct key (or other token) is present. This prevents the car from being "hot wired" after entry has been acheived.
Early models used a static code in the ignition key (or keyfob) which was recognised by an RFID loop around the lock barrel and checked against the vehicle's ECU for a match.
If the code is unrecognised, the ECU will not allow fuel to flow and ignition to take place. Later models use rolling codes or advanced cryptography to defeat copying of the code from the key or ECU.
love4cars si roBERT au dat un raspuns corect - dar mai scurt 😂 😂
  • roBERT
Pot decat sa presupun ca uasta se intampla deoarece unii folosesc mai rar diferitele functii ale tastaturii (ctrl + c...) 😊
Eu imi permit sa acord nota de trecere raspunsului postat de tine.
  • zafirul
hai maaaa... doar nota de trecere....
si eu care am folosit si culori, si bold... 😭
  • gokey
  • Mesaje scrise: 32
  • Cont inregistrat: 04 Jul 2007
immobilizatorul permite pornirea masinii doar cu cheile care au fost in prealabil programate
chiar daca ai o cheie care functioneaza mecanic, dar nu contine un cip care a fost programat pentru acea masina , nu vei putea porni masina
  • ccostras
  • Mesaje scrise: 712
  • Masina: Omega 2002 Y25DT
  • Cont inregistrat: 21 Jan 2007
Cum pot afla daca masina mea are incorporat acel imibiliser? Omega 2002, 2,5 DTI.Nu am cumparat masina cu cartea tehnica.
  • bogdanene
  • Mesaje scrise: 695
  • Masina: Astra 2001 Y 20 DTH
  • Cont inregistrat: 11 Nov 2005
pai in mod cert, ai si tu.
doar daca nu a fost "masluita".
  • gokey
  • Mesaje scrise: 32
din 1995 toate au !
  • sebastianB
  • Mesaje scrise: 8
  • Masina: Astra 2005
  • Cont inregistrat: 30 Jul 2007
ce fel de semnal emite cipul de la cheie (IR, unde radio..)?
  • gokey
  • Mesaje scrise: 32
frecventa radio
  • sebastianB
  • Mesaje scrise: 8
cit timp tine bateria la cheie?
  • gokey
  • Mesaje scrise: 32
bateria ptr. telecomanda?
daca este o baterie de calitate atunci trebuie sa tina 1-2 ani
  • sebastianB
  • Mesaje scrise: 8
asa'i ca nu mai merge imobilizeruldaca se duce bateria ?
  • gokey
  • Mesaje scrise: 32
cipul nu este alimentat de nici o baterie !
ce problema ai ?
trimite PM
  • k8m3l
  • Mesaje scrise: 21
  • Masina: Vectra 2002 y20dth
  • Cont inregistrat: 03 Feb 2007
as vrea sa stiu si eu mai multe despre asta eu am o vecta c 2002 si vreau sa schimb cheia sa imi iau una briceag sau alta in care sa intre inc centr fiindca am fost cu cheia masinii sa vad cum e cu acel cip si cei care fac asa ceva mi-au pus cheia pe bucati pe un aparat si au gasit semnalul de la cip in inc centr plus ca au zis ca cel putin ptr vectra c nu exista licenta de la gm sa multiplice chei asa ca un sfat de cineva 'priceput' ar fi de mare ajutor ( mentionez ca nu am masina de noua si a fost condusa de o femeie inainte de mine care nu prea si-a taiat unghiile cam asta ar fi motivul)
vectra c 2odti
  2. Tutoriale
