![Very Happy](http://www.clubopel.com/images/2013/blank.gif)
deci ... totul era sa citim acea descriere (nfo) pe care au facut-o rusii ...
am incercat sa instalez epc4 cu aceeasi metoda ca si 3 (Daemon Tools Pro)... n-a mers (dadea eroarea de dvd) ... bun ...
citesc acolo ... ei au folosit alt program Alcohol 52% ... eu Alcohol 120% (versiunea mai noua)
solutia:
1. There is no need to disconnect anything, in terms of pull power from the CD drive.
2. We put 52% Alcohol. What is fresh - the better.
3. In emulation settings put daw "emulation RMPS"
4. In the emulation settings set emulation daw "BAD Sectors Emulation"
5. Start-All Programs-Alcohol52%-ACID Wizard. In the resulting window put all Jackdaws, if not the face (although should), and click the button Cloak. Minimize the program window.
6. We mount an image EPC4
7. Start the installation EPC4, if not started automatically.
*** asta e traducerea dupa tata gugal - nu dati in mine ....
a mers uns instalarea ...
deci ... Enjoy!
ps: daca solutia incalca regulamentul rog pe cineva cu "putere" sa modifice/stearga ce nu e Ok... mersic
