sigurante Vectra C/Signum (2002 - 2008)
Vauxhall Vectra C/Signum (2002 - 2008) fuses
Înapoi la 🇷🇴 Opel Vectra C
Sigurante Insignia B facelift (2020 - 2022) Sigurante Zafira A (1999 - 2005)
Instrument panel fuse box (LHD: driver's side, RHD: passenger compartment)
  • The fusebox is on the left, on the outside of the instrument panel. Open door. Disengage cover by pulling firmly and remove.
locatie si diagrama tablou sigurante bord Opel Vectra C si Signum
1 Infotainment system 20 A
2 Interior fan, heating, air conditioning system 7.5 A
3 Sunroof 20 A
5 Door module control unit 7.5 A
6 Brake light 7.5 A
7 Bodywork module control unit 30 A
8 Control unit front passenger door module 30 A
9 Central control unit 7.5 A
10 Control unit Steering column module 7.5 A
11 Diagnostics plug 7.5 A
12 Battery overload protection 15 A
13 -
15 Door module control unit 30 A
16 -
17 Instruments, information display 15 A
18 Ignition terminal 15, Air conditioning
MY2008: -
7.5 A
19 -
20 Yaw rate sensor (ESPPlus) 7.5 A
21 Infotainment system
MY2008: -
7.5 A
22 Cigarette lighter 30 A
23 Interior fan, air conditioning,
Electronic Climate Control
30 A
40 A
25 Heating, air conditioning system 7.5 A
26 Instruments, information display 7.5 A
27 -
Instrument panel relays
diagrama relee bord Opel Vectra C si Signum
K2_X129 Terminal 15a
K3_X129 Terminal 15
K4_X129 Blower, Passenger Compartment
K5_X129 Blower, Passenger Compartment
Load compartment fuse box
  • The fusebox is located on the left side of the luggage compartment, in the stowage compartment.
  • Saloon / Hatch: Press the latch down and open the cover.
  • Estate: Press both latches down and open the cover and interior trim.
locatie si diagrama tablou sigurante portbagaj Opel Vectra C si Signum
3 Electric seat adjustment, driver's seat 40 A
4 Heated rear window 40 A
5 Electric seat adjustment, front passenger's seat 40 A
6 Electric window operation, right rear 30 A
7 Electric window operation, left rear 30 A
8 Seat heating, rear right 15 A
9 Horn, Vauxhall alarm system 15 A
10 Fuel pump 20 A
11 Battery voltage 25 A
12 Seat heating, rear left 15 A
13 Towing equipment 20 A
14 Tailgate wiper 15 A
15 Heated seats, seat climate control, left front 15 A
16 Seat heating, front right 15 A
17 Accessory socket 15 A
18 Tailgate locking, Estate 30 A
19 Terminal 30
MY2008: Terminal 30, Twin Audio
10 A
20 Tank flap locking 7.5 A
21 Ultrasonic sensor, Vauxhall alarm system 5 A
22 Electrically operated tailgate 30 A
23 Glass breakage sensor (Vauxhall alarm system) 7.5 A
24 Battery voltage 25 A
25 Electronic chassis 10 A
26 Terminal 15 (starter switch)
MY2008: Terminal 15 (starter switch), Twin Audio
25 A
27 Seat occupancy recognition, tyre pressure monitoring system, rain sensor, air conditioning system 5 A
28 Parking distance sensors 7.5 A
29 -
Load compartment relays
Schema relee portbagaj Opel Vectra C/Signum
K1_X97 Terminal 15
K2_X97 Wiper, back window
K3_X97 Fuel pump
K4_X97 Signal horn, anti-theft warning system
K5_X97 Seat heating, rear, left
K6_X97 Seat heating, rear, right
K7_X97 Heated back window
K8_X97 Central locking, flap fuel filler
  • The fuse box is in the box at the front left side of the engine compartment.
  • Disengage the bar at the front of the cover of fuse box and swing it upwards.
locatie cutie dreapta sigurante motor Opel Vectra C si Signum
1 Engine electronics, transmission electronics 20 A
2 Starter 25 A
3 Horn 20 A
4 Air conditioning system, Electronic Climate Control 10 A
5 Windscreen wash system, front and rear 15 A
MY2008: Diesel fuel filter heating
MY2008: 30 A
7 Central control unit, ESP Plus 15 A
8 Headlights, windscreen wash nozzles 10 A
9 Power steering
MY2008: Power steering, brake servo
7.5 A
10 Adaptive Forward Lighting 10 A
11 Windscreen wiper 30 A
12 Central control unit, ESP Plus 7.5 A
13 Headlight wash system 30 A
14 Oxygen sensor 10 A
15 Engine control unit1) 10 A
16 ABS 5 A
17 -
18 -
19 Adaptive Forward Lighting,
headlight range adjustment,
xenon headlight system
15 A
5 A
15 A
20 Headlight range adjustment 5 A
21 -
22 Windscreen wiper 30 A
23 Auxiliary heating 20 A
24 Battery voltage, terminal 30 30 A
25 Battery voltage, terminal 30 30 A
26 -
27 Easytronic 30 A
28 Tailgate module control unit 60 A
29 ABS 40 A
30 Tailgate module control unit 60 A
31 Vehicle interior module control unit 60 A
32 ABS 40 A
33 Vehicle interior module control unit 60 A
34 Tailgate module control unit 60 A
35 Cooling fan2) 30 A
40 A
36 Cooling fan2)
MY2008: Cooling fan2),
Brake servo (30 A)
20 A
30 A
20 A
30 A
30 A
37 Adaptive Forward Lighting: Slot for changing to symmetrical dipped beam for driving abroad orice siguranță de intensitate mare A
38 -
1) The brake lights are on all the time if the fuse is d efec tive an d the ignitio n is switched on.
2) Depending on engine.
Engine compartment relays
Vauxhall Vectra C/Signum engine compartment relays diagram
K1_X125 Starter
K2_X125 Engine Control Unit (ECU)
K3_X125 Terminal 15
K5_X125 Wiper, winscreen, low/high
K6_X125 Wiper, winscreen, on/off
K7_X125 Wsher pump, headlamps
K8_X125 Air Conditioning (AC) compressor
Engine compartment fuses (auxiliary unit)
Sigurante compartiment motor (unitate auxiliară) Opel Vectra C și Signum
38 Type 1: Starter
Type 2: Glow plug control unit
30 A
60 A
39 Type 1: Horn
20 A
60 A
40 -
41 Type 1: empty
Type 2: Fuel filter heater relay
30 A
Engine compartment relay (auxiliary unit)
Releu compartiment motor (unitate auxiliară) Opel Vectra C și Signum
K1_X161A Secondary air injection
K1_X161 Fuel filter heating
Additional resources
Owners manual (EN, pdf) (p. 246)
