sigurante Insignia B (2017 - 2020)
Vauxhall Insignia B (2017 - 2020) fuses
Înapoi la 🇷🇴 Opel Insignia B
Sigurante Insignia A facelift (2013 - 2017) Sigurante Insignia B facelift (2020 - 2022)
  • The fuse box is in the front left of the engine compartment. Disengage the cover and remove it.
locatie sigurante motor Insignia B
tablou sigurante motor Insignia B
tablou sigurante motor Insignia B cu diagrama si tabel
3 ABS
6 Tailgate
7 Fog lights
8 Memory module
9 Heated windscreen and/or Heated seats
10 Seat lumbar
11 DC/DC battery
12 Heated rear window
13 Heated mirror
15 -
16 Front wiper
17 Power seat, passenger
18 Sunblind
19 Power seat, driver
21 Sunroof
22 Rear wiper/Airbag
23 Adaptive forward lighting
25 -
26 Transmission control module
27 Ignition/Instrument panel
29 Rear view camera/Air vent
30 Malfunction indicator light/ Trailer
32 Camera
33 Seat heat front
34 Seat heat rear
35 Damping/All-wheel drive
36 Fuel system
37 -
38 -
39 -
40 Steering wheel lock
41 -
42 -
43 Heated steering wheel
44 Headlight range adjustment
45 -
46 Engine control module
47 -
48 DC/DC converter/Air vent/EBoost
49 Rear door control module
50 -
51 -
52 -
53 -
54 -
55 -
56 Starter
57 -
58 -
59 Left headlight (LED)
60 Cooling fan
61 -
62 -
63 -
64 -
65 Climate control
66 -
67 -
68 -
69 Right high beam (Halogen)/ Right headlight (LED)
70 Left high beam (Halogen)
71 -
72 Starter
73 -
74 Transmission control module
75 Engine control module
76 Exhaust reduction system
77 -
78 Horn
79 Washer system
80 -
81 Engine control module
82 -
83 Ignition coil
84 Ignition coil
85 Powertrain
86 -
87 Diesel fuel heating
88 Air shutter
89 -
90 -
91 -
92 After boil pump
93 Electronic key system
94 -
95 Coolant pump
96 Diesel fuel heating
97 -
98 -
99 Coolant pump
  • In left-hand drive vehicles, the fuse box is behind a cover in the instrument panel. Disengage cover at the side and remove.
  • In right-hand drive vehicles, the fuse box is located behind a cover in the glovebox. Open the glovebox and remove the cover.
locatie sigurante bord partea soferului Insignia B
tablou sigurante bord Insignia B
tablou sigurante bord Insignia B cu volan pe dreapta
tablou sigurante bord Insignia B cu diagrama si tabel
1 Left power window
2 Right power window
3 Body control module
4 Climate control fan
5 Body control module
6 Trailer provisions
7 Rear seat power folding
8 Body control module
9 Engine control module
10 Head-up display
11 NOx reduction/Pipe heater
12 NOx reduction/Soot sensor
13 Adblue/UREA module
14 Heated steering wheel
15 Transmission control module
16 Amplifier
17 Alarm
18 Body control module
19 Adblue/UREA module
20 Body control module
21 Body control module
22 Body control module
23 Electric steering wheel lock
24 Airbag
25 Diagnostic connector
26 Power outlet load compartment
27 EBCM valve
28 Police provision
29 -
30 -
31 Steering wheel controls
32 Ignition switch
33 Climate control
34 Central gateway module
35 AUX/USB connector
36 Wireless charger
37 Rear wiper
38 Onstar
39 Display
40 Parking assist
41 Overhead console
42 Radio
