sigurante Insignia B facelift (2020 - 2022)
Vauxhall Insignia B facelift (2020 - 2022) fuses
Înapoi la 🇷🇴 Opel Insignia B
Sigurante Insignia B (2017 - 2020) Sigurante Vectra C/Signum (2002 - 2008)
  • The fuse box is in the front left of the engine compartment. Disengage the cover and remove it.
locatie sigurante motor Insignia B facelift
tablou sigurante motor Insignia B facelift
tablou sigurante motor Insignia B facelift cu diagrama si tabel
3 ABS
5 Load compartment fuse box
6 Tailgate
7 Rear fog light / Front fog lights
8 Memory module
9 Heated windscreen
10 Seat lumbar
11 DC / DC battery
12 Heated rear window
13 Heated mirror
15 LED headlights
16 Front wiper
17 Power seat, passenge
18 Sunblind
19 Power seat, driver
21 Sunroof
22 Rear wiper
23 Rear seat power folding
25 -
26 Transmission control module
27 Ignition / Instrument panel
29 Rear view camera / Air vent
30 Malfunction indicator light / Trailer
32 -
33 Seat heating front
34 Seat heating rear No.Circuit
35 Damping / All-wheel drive
36 Fuel system
37 -
38 -
39 -
40 Steering wheel lock
41 -
42 -
43 Heated steering wheel
44 Headlight range adjustment
45 -
46 Engine control module
47 -
48 DC/DC converter
49 Rear door control module
50 -
51 -
52 -
53 -
54 -
55 -
56 Starter
57 Load compartment fuse box
58 -
59 Alarm siren
60 Cooling fan
61 -
62 -
63 -
64 -
65 Climate control
66 -
67 -
68 -
69 -
70 -
71 -
72 Starter
73 -
74 Transmission control module / Engine cooling
75 Engine control module
76 Exhaust reduction system
77 -
78 Horn
79 Washer system
80 -
81 Engine control module
82 -
83 Ignition coil
84 Ignition coil
85 Other fuse are
86 -
87 Diesel fuel heating
88 Air shutter
89 -
90 -
91 -
92 -
93 Electronic key system
94 -
95 Coolant pump
96 Diesel fuel heating
97 -
98 -
99 -
locatie sigurante bord partea soferului Insignia B facelift
tablou sigurante bord Insignia B facelift
tablou sigurante bord Insignia B facelift cu volan pe dreapta
tablou sigurante bord Insignia B facelift cu diagrama si tabel
1 Left power window
2 Right power window
3 Body control module
4 Climate control fan
5 Body control module
6 Trailer provisions
7 LED headlight left
8 Body control module
9 Engine control module
10 Head-up display
11 NOx reduction / Pipe heater
12 NOx reduction / Soot sensor
13 AdBlue module
14 Heated steering wheel
15 Transmission control module
16 Amplifier
17 LED headlight right
18 Body control module
19 AdBlue module
20 Body control module
21 Body control module
22 Body control module
23 Electric steering wheel lock
25 Diagnostic connector
26 Power outlet load compartment
27 ABS
28 Police or taxi provision
29 Fuel pump
30 Fuel pump
31 Steering wheel controls
32 Ignition switch
33 Climate control
34 Central gateway module
35 AUX / USB connector
36 Wireless charger
37 Rear wiper
38 Emergency call
39 Display
40 Parking assist
41 Overhead console
42 Infotainment System
43 Police car systems
44 Power outlet
  • The fuse box is located on the left side of the load compartment behind a cover. Remove the cover. Disengage the fuse box cover and remove it.
  • Notice: Not all fuses or this fusebox may not be fitted.
locatie sigurante portbagaj Insignia B facelift
tablou sigurante portbagaj Insignia B facelift
tablou sigurante portbagaj Insignia B facelift cu diagrama si tabel
3 Trailer interface module
5 Power tailgate hands-free sensor
8 Power tailgate
11 Trailer outlet
12 Seat heating front left
13 Seat heating front right
15 Seat heating rear 1
16 Seat heating rear 2
17 -
18 Trailer outlet
19 -
21 -
22 Power tailgate
