sigurante Insignia A facelift (2013 - 2017)
Vauxhall Insignia A facelift (2013 - 2017) fuses
Înapoi la 🇷🇴 Opel Insignia A
Sigurante Insignia A (2008 - 2013) Sigurante Insignia B (2017 - 2020)
  • There may be up to three fuse boxes in the vehicle:
    - in the front left of the engine compartment
    - on the left side of the instrument panel
    - behind a cover on the left side of the load compartment.
  • Depending on the vehicle equipment the configuration of fuses in the fuse boxes are different, indicated by type A and type B in the tables.
  • Type A means all 5-door hatchback and 4-door saloon variants, and also Sports Tourer or Country Tourer with power tailgate or trailer hitch or rear power outlets.
  • Type B means Sports Tourer or Country Tourer without power tailgate, without trailer hitch and without rear power outlets
  • The fuse box is in the front left of the engine compartment.
  • Disengage the cover, lift it upwards and remove.
locatie sigurante motor Insignia A facelift
tablou sigurante motor Insignia facelift
tablou sigurante motor Insignia facelift cu diagrama si tabel
1 Transmission control module
2 Engine control module
3 -
5 Ignition/Transmission control module/Engine control module
6 Windscreen wiper
8 Fuel injection/Ignition system
9 Fuel injection/Ignition system
10 Engine control module
11 Lambda probe
12 Starter
13 Sensor throttle heating
14 Lighting
15 Rear window wipe
16 Vacuum pump/Mass air flow meter/Water in fuel sensor/DC transformer
17 Additional tail lights (type B)
18 Adaptive forward lighting
19 Adaptive forward lighting
20 Fuel pump
21 Rear power windows
22 ABS
23 Variable effort steering
24 Front power windows
25 Power outlets (type A)
26 ABS
27 Electric parking brake
28 Heated rear window
29 Left power seat
30 Right power seat
31 Air conditioning system
32 Body control module
33 Heated front seats
34 Sunroof (type A)
Tailgate locking (type B)
35 Infotainment system (type A)
36 -
37 Right high beam
38 Left high beam
39 -
40 -
41 Vacuum pump
42 Radiator fan
43 Vehicle battery/DC transformer (only on vehicles with stop-start system)
44 Headlamp washer syste
45 Radiator fan
46 Terminal 87/Main relay
47 Lambda probe
48 Fog lights
49 Right low beam
50 Left low beam
51 Horn
52 Ignition
53 Ignition/Ventilated front seats
54 Ignition
55 Power windows/Mirror folding
56 Windscreen washer
57 -
58 -
59 Diesel fuel heating/Emission control system
60 Mirror heating
61 Mirror heating
62 Heated steering wheel (only vehicles without load compartment fuse box)
63 Rear window sensor
64 Adaptive forward lighting
65 Auxiliary pump (only on vehicles with stop-start system)
66 Rear window washer system
67 Fuel system control module
68 -
69 Vehicle battery sensor
70 Rain sensor
71 Vehicle battery sensor
  • Open compartment, compress the locking tabs, fold compartment down and remove.
  • Power seats, No's. 12 and 13, have an overload protection. The circuit will be closed again after cooling down.
  • In right-hand drive vehicles, the fuse box is located behind a cover in the glovebox. Open the glovebox and remove the cover.
locatie sigurante bord partea soferului Insignia A facelift
tablou sigurante bord Insignia A facelift
tablou sigurante bord Insignia A facelift cu diagrama si tabel
1 Infotainment system/Info display/Anti-theft alarm system
2 Body control unit
3 Body control unit
4 Infotainment system/Info display
5 Infotainment system/Info display/High beam assist
6 Cigarette lighter
7 Power outlet
8 Body control unit
9 Body control unit
10 Body control unit
11 Interior fan
12 -
13 -
14 Diagnostic connector
15 -
16 Central locking system/Tailgate
17 Air conditioning system
18 Transportation fuse
19 Memory
21 Instrument
22 Ignition/Central locking system/ Electronic key system
23 Body control unit
24 Body control unit
25 Steering wheel control
26 Power outlet load compartment
Load compartment fuse box
  • The fuse box is on the left side of the load compartment behind a cover. Remove the cover.
locatie sigurante portbagaj Insignia A facelift
tablou sigurante portbagaj Insignia A facelift
tablou sigurante portbagaj Insignia A facelift cu diagrama si tabel
1 Central locking system/Electronic key system
2 Trailer module (type A)
Infotainment system (type B)
3 -
5 Trailer socket
6 Heated steering wheel (only vehicles with load compartment fuse box)
7 Selective catalytic reduction system
8 Trailer socket
9 Sunroof
10 Central locking system/Tailgate (type A)
Sunroof (type B)
11 -
12 Selective catalytic reduction system
13 -
15 Power tailgate lock
16 Air conditioning system
17 Selective catalytic reduction system
18 Selective catalytic reduction system
19 Side obstacle detector
20 Side obstacle detector/Ventilated front seats
21 Active damping system/Cruise control/Traffic sign assistant/ Lane departure warning/Trailer module
23 All-wheel drive/Anti-theft alarm system
25 -
26 -
27 -
29 Trailer module/Transportation fuse (type A)
30 Side obstacle detector
32 -
33 -
34 Sunroof
35 -
36 -
37 -
