sigurante Corsa F (2019 - 2024)
Vauxhall Corsa F (2019 - 2024) fuses
Înapoi la 🇷🇴 Opel Corsa F
Sigurante Corsa D (2006 - 2014) Sigurante Insignia A (2008 - 2013)
Engine compartment fuse box (non-EV)
locatie sigurante motor Corsa F
tablou sigurante motor Corsa F
tablou sigurante motor Corsa F full cu diagrama si tabel
1 Climate control system
2 Brake system
3 Fuse box (right side of the instrument panel)
4 Brake system
5 Body control module
6 Cooling fan
7 Body control module
8 Engine control module / Fuel pump
9 NOX sensor / Diesel water sensor
10 Engine control module
11 Engine control module
12 Diagnostic link connector
13 Body control module
14 Battery sensor
15 Trailer control module
16 Right headlight
17 Engine control module / NOX sensor
18 Right high beam
19 Left high beam
20 Engine control module / Fuel pump / Diesel heater
21 Starter
22 Automatic transmission
23 unspecified
24 unspecified
25 Fuse box (trailer)
26 unspecified
27 Body control module
28 Selective catalytic reduction system
29 Windscreen wiper
30 unspecified
31 Climate control system
32 Steering wheel
Engine compartment fuse box (electric vehicles)
locatie sigurante motor Corsa F electrice
tablou sigurante motor Corsa F electrice
tablou sigurante motor vehicule electrice Corsa F full cu diagrama si tabel
2 Brake system
4 Brake system
5 unspecified
6 Cooling fan
8 Valve climate control
9 Electric vehicle control unit
10 Electric vehicle control unit (climate compressor)
11 Electric vehicle control unit
13 Body control module / Climate control system
14 unspecified
15 E-service plug
16 Right headlight
17 unspecified
18 Right high beam
19 Left high beam
20 Electric vehicle control unit
21 unspecified
22 Engine compartment relay
23 AC/DC converter / DC/DC converter
24 unspecified
25 High voltage battery interface
26 Motor controller (electric motor and inverter)
28 unspecified
29 Windscreen wiper
30 Body control module
31 Body control module
32 Steering wheel
Instrument panel fuse box (non-EV)
  • Fuse box on the left side of the instrument panel
  • In right-hand drive vehicles, the fuse box is located behind a cover in the glovebox. Open the glovebox and remove the cover.
locatie sigurante bord stanga sofer Corsa F
tablou sigurante bord stanga sofer Corsa F
tablou sigurante bord stanga sofer Corsa F full cu diagrama si tabel
1 Radar / Interior mirror
3 Inductive charging
4 Horn
5 Windscreen washer
6 Windscreen washer
8 Rear wiper
9 unspecified
10 Central locking system
11 Central locking system
12 Diagnostic connector module
13 Climate control system
14 Alarm / Vauxhall Connect
15 unspecified
16 unspecified
17 Instrument cluster
18 unspecified
19 unspecified
20 unspecified
21 Power button / Anti-theft locking system
22 Rain sensor / Light sensor / Camera
23 Seatbelt reminder
24 Infotainment / Parking assist / Rear view camera
25 Airbag
26 unspecified
27 Anti-theft alarm system
28 unspecified
29 Infotainment
30 unspecified
31 Cigarette lighter / 12 V power outlet
32 Heated steering wheel
33 Climate control system / Automatic transmission
34 Parking assist / Exterior mirror adjustment
Instrument panel fuse box (electric vehicles)
locatie sigurante bord stanga sofer Corsa F electrice
tablou sigurante bord stanga sofer Corsa F electrice
tablou sigurante bord stanga sofer Corsa F electrice full cu diagrama si tabel
2 unspecified
4 Horn
5 Windscreen washer
6 Windscreen washer
8 Rear wiper
9 unspecified
13 Climate control module / radio faceplate
15 Electronic shifter module / Headlight control unit
16 Low voltage network separation device
18 Reserved for Aftersales equipment
19 Steering column control / Steering wheel controls
20 unspecified
21 Power button
25 Airbag
26 unspecified
28 unspecified
29 Infotainment
30 unspecified
33 Right front headlight
Fuse box on the right side of the instrument panel
  • In right-hand drive vehicles, the fuse box is located behind a cover in the instrument panel. Disengage cover at the bottom side and remove. Remove the bracket.
locatie sigurante bord dreapta/torpedo Corsa F
tablou sigurante bord dreapta/torpedo Corsa F
tablou sigurante bord dreapta/torpedo Corsa F full cu diagrame si tabel
1 Heated rear window
2 Heated exterior mirrors
3 Power windows front
4 Exterior mirror adjustment / Folding mirrors
5 Power windows rear
6 unspecified
7 unspecified
8 Fuse box (right side of the instrument panel)
9 unspecified
10 Heated front seats
11 Seat massage function
Additional resources
Owners manual (EN, pdf) (p. 203)
