sigurante Corsa D (2006 - 2014)
Vauxhall Corsa D (2006 - 2014) fuses
Înapoi la 🇷🇴 Opel Corsa D
Sigurante Astra L (2021 - prezent) Sigurante Corsa F (2019 - 2024)
  • There are three fuse boxes in the vehicle:
  • — in the front left of the engine compartment
  • — in left-hand drive vehicles, in the interior behind the light switch, or, in right-hand drive vehicles, behind the glovebox
  • — behind a cover on the left side of the load compartment
  • The fuse box is in the front left of the engine compartment.
  • Disengage the cover, lift it upwards and remove.
locatie sigurante motor Corsa D
tablou sigurante motor Corsa D
tablou sigurante motor Corsa D full cu diagrama si tabel
1 Starter
2 Air conditioning system
3 Diesel fuel filter heater
4 Horn
5 Manual transmission automated, automatic transmission
6 Engine control unit
7 Fog lights
8 Engine cooling
9 Engine cooling
10 Manual transmission automated
11 Glow plugs, ignition system
12 Headlight range adjustment, Adaptive forward lighting
13 Air conditioning system
14 Manual transmission automated
15 High beam (right)
16 High beam (left)
17 Main relay
18 Engine control unit
19 Airbags
20 Main relay
21 Main relay
22 Central control unit
23 Tyre repair kit
24 Fuel pump
25 ABS
26 Heated rear window
27 ABS
28 Interior fan
29 Cigarette lighter
30 Air conditioning system
31 Power window (left)
32 Power window (right)
33 Heated exterior mirrors
34 -
35 -
  • In left-hand drive vehicles, the fuse box is behind the the light switch. Pull the top edge of the panel and fold down.
  • In right-hand drive vehicles, the fuse box is located behind a cover in the glovebox. Open the glovebox and remove the cover. To close, first put on the cover, then lock it into position.
locatie sigurante bord stanga sofer Corsa D
tablou sigurante bord stanga RHD / Vauxhall Corsa D
tablou sigurante bord stanga sofer Corsa D
tablou sigurante bord stanga sofer Corsa D full cu diagrama si tabel
2 Instruments, Info-Display
3 Radio
4 Ignition switch
5 Windscreen washer system
6 Central locking system, tailgate
7 Central locking system
8 -
9 Courtesy light
10 Electrical power steering
11 Light switch, brake light
12 ABS, brake light
13 Heated steering wheel
14 Parking assist, rain sensor, interior mirror
Load compartment fuse box
  • The fuse box is on the left side of the load compartment behind a cover. Remove the cover.
locatie sigurante portbagaj Corsa D
tablou sigurante portbagaj Corsa D
tablou sigurante portbagaj Corsa D full cu diagrame si tabel
1 Adaptive forward lighting
3 Seat heater (left)
4 Seat heater (right)
8 Rear carrier system, towing equipment
11 -
12 -
13 -
15 Rear carrier system, towing equipment
16 -
17 Sunroof
Additional resources
Owners manual (EN, pdf) (p. 152)
