sigurante Astra L (2021 - prezent)
Vauxhall Astra L (2021 - prezent) fuses
Înapoi la 🇷🇴 Opel Astra L
Sigurante Astra K facelift (2019 - 2021) Sigurante Corsa D (2006 - 2014)
  • Unfortunately, the users manual does not provide any information about the fuse box.
  • The only recommendation is: "A defective fuse must be replaced by a workshop."
  • We will update the page as soon as this information becomes available.
