sigurante Astra K (2016 - 2019)
Vauxhall Astra K (2016 - 2019) fuses
Înapoi la 🇷🇴 Opel Astra K
Sigurante Astra J (2009 - 2015) Sigurante Astra K facelift (2019 - 2021)
  • The fuse box is in the front left of the engine compartment. Disengage the cover and remove it.
locatie sigurante motor Astra K
tablou sigurante motor Astra K
tablou sigurante motor Astra K cu diagrama si tabel
1 Starter
2 Starter
3 Exhaust sensor
4 Engine control module
5 Engine functions
6 Transmission control module
8 Engine control module
9 Climate control system
10 2016: -
2017+: Diesel exhaust system
11 Tailgate locking system, Transmission
12 Seat lumbar massage
13 After boil pump
14 2016: -
15 Exhaust sensor
16 Fuel injection
17 Fuel injection
18 2016: -
19 2016: -
2017-2019: Diesel exhaust system
2020+: -
21 DC/AC Converter
22 ABS
23 Washer system for windscreen and rear window
25 Diesel fuel heating
26 Transmission control module
27 Power tailgate module
29 Heated rear window
30 2016: -
2017+: Mirror defrost
32 2016: DC transformer/LED display/ Electrical heater/Climate control/Glow plug controller/Fuel pump;
2017+: DC transformer/LED display/ Electrical heater/Climate control/Glow plug controller
33 2016: -
2017-2019: Anti theft warning
2020+: -
34 Horn
35 2016-2019: Power outlet load compartment
2020+: Engine control module
36 Right high beam (Halogen)/ Right low beam (LED)
37 Left high beam (Halogen)
38 LED headlight/Automatic headlight range adjustment
39 Front fog light
40 2016-2019: OnStar
2020+: Central gateway module
41 2016-2019: Water in fuel sensor/Water pump
2020+: -
42 Manual headlight range adjustment
43 Fuel pump
44 Rear view camera/Inside rear view mirror/Trailer module
45 LED headlight left/Automatic headlight range adjustment left
46 Instrument cluster
47 Steering column lock
48 Rear wiper
49 -
50 LED headlight right/Automatic headlight range adjustment right
51 Left low beam (LED)
52 Engine control module/Transmission control module
53 -
54 Windscreen wiper
55 2016: -
56 -
57 -
  • Pull the cover and remove.
  • Vehicles with power connector:
    If the fuse cover has a power connector, it must be removed by using an adapter and a screwdriver. The adapter is stowed in the glovebox (p. 70). The screwdriver is stowed in the load compartment (p. 236).
    Attach the adapter to the power connector.
    Push the screwdriver through the recess in the adapter.
  • After having changed defective fuses, close the fuse box cover and press until it engages.
    1. Apply the cover on the right side.
    2. Fold the left side of the cover forwards. Take care that the securing clamp is guided as shown in the illustration.
locatie sigurante consola centrala Astra K
atasare adaptor astra k
inserare surubelnita in adaptor astra k
panou sigurante consola centrala Astra K
instructiuni inchidere panou sigurante consola centrala Astra K
panou sigurante consola centrala Astra K cu diagrama si tabel
1 2016-2019: -
2020+: Backseat heating (on vehicles with alarm horn)
2 Climate control system, fan
3 Power seat driver side
4 2016-2019: Cigarette lighter/Power outlet front
2020+: Front passenger electric seat
5 2016-2019: -
2020+: ABS
6 Power window front
7 2016-2019: ABS
2020+: -
8 Heated steering wheel
9 Body control module
10 Power window rear
11 Sunroof
12 Body control module
13 Seat heating (only on vehicles without alarm horn)
14 Exterior mirror
15 Body control module
16 Body control module
17 Body control module
18 Body control module
19 Data link connector
20 Airbag system
21 Climate control system
22 Central locking system, tailgate
23 Electronic key system
24 Power seat memory function
25 2016: Steering wheel lighting
2017+: Airbag system steering wheel
26 Ignition switch/Steering column lock
27 Body control module
28 USB socket
29 2016-2019: -
2020+: Front cigarette lighter/outlet
30 Selector lever
31 Rear window wiper
32 Transmission control module
33 Anti-theft alarm system/Power sounder
34 Parking assist/Side blind spot alert/Infotainment system/USB socket
35 OnStar
36 Info display/Instrument cluster/ CD player
37 Infotainment system, radio
Load compartment fuse box
  • The fuse box is located on the left side of the load compartment behind a cover.
  • Remove the cover.
  • Disengage the fuse box cover and remove it.
locatie sigurante portbagaj Astra K
capac sigurante portbagaj Astra K
tablou sigurante portbagaj Astra K
tablou sigurante portbagaj Astra K cu diagrama si tabel
2 DC/AC Inverter
3 Trailer module
4 Power seat passenger side
6 Distance warning module
8 -
9 Rear seat heating (on vehicles without alarm horn)
10 2016: -
2017-2019: Service
2020+: -
11 2016-2019: -
2020+: Amplifier
12 Front seat heating (on vehicles with alarm horn)
13 Rear seat heating (on vehicles with alarm horn)
14 2016: Heated steering (on vehicles with alarm horn)
2017+: Ignition
15 Seat ventilation
16 Trailer outlet
17 Trailer outlet
18 -
19 -
21 Electrical rear seat folding
22 2016: -
2017-2019: Power tailgate
2020+: -
