sigurante Astra J (2009 - 2015)
Vauxhall Astra J (2009 - 2015) fuses
Înapoi la 🇷🇴 Opel Astra J
Sigurante Astra H (2004 - 2010) Sigurante Astra K (2016 - 2019)
  • The fuse box is in the front left of the engine compartment. Disengage the cover, lift it upwards and remove.
  • After having changed defective fuses close the fuse box cover and press until it engages.
locatie tablou sigurante motor Astra J
tablou sigurante motor Astra J cu diagrama si tabel
1 Engine control module
2 Lambda probe
3 Fuel injection, ignition system
4 Fuel injection, ignition system
6 2009-2012: Mirror heating
2013+: Mirror heating/Anti-theft alarm system
7 2009-2012: Fan control
2013+: Fan control/Engine control module/Transmission control module
8 2009-2012: Lambda probe, engine
2013+: Lambda sensor/Engine cooling
9 Rear window sensor
10 Battery sensor
11 Trunk release
12 Adaptive forward lighting module
13 2009-2012: empty slot
2013+: ABS
14 Rear window wiper
15 Engine control module
16 Starter
17 Transmission control module
18 Heated rear window
19 Front power windows
20 Rear power windows
21 2009-2012: ABS
2013+: Rear electrical centre
22 Left high beam (Halogen)
23 Headlamp washer system
24 Right low beam (Xenon)
25 Left low beam (Xenon)
26 Front fog lights
27 Diesel fuel heating
28 2009-2012: empty slot
2013+: Start stop system
29 Electrical parking brake
30 ABS
31 2009-2012: empty slot
2013+: Adaptive cruise control
32 Airbag
33 2009-2012: Adaptive forward lighting
2013+: Adaptive forward lighting/Automatic light control
34 2009-2012: empty slot
2013+: Exhaust gas recirculation
35 2009-2012: Power windows
2013+: Exterior mirror/Rain sensor
36 2009-2012: empty slot
2013+: Climate control
37 Canister vent solenoid
38 Vacuum pump
39 2009-2012: Fuel system control module
2013+: Central control module
40 Windscreen washer, Rear window washer system
41 Right high beam (Halogen)
42 Radiator fan
43 Windscreen wiper
44 2009-2012: empty slot
2013+: Windscreen wiper
45 Radiator fan
46 -
47 Horn
48 Radiator fan
49 Fuel pump
50 2009-2012: Headlamp levelling
2013+: Headlamp levelling/Adaptive forward lighting
51 Air shutter
52 Auxiliary heater, diesel engine
53 Transmission control module, Engine control module
54 2009-2012: Wiring monitoring
2013+: Vacuum pump/Instrument panel cluster/Heating ventilation/Air conditioning system
  • In left-hand drive vehicles, the fuse box is behind the storage compartment in the instrument panel.
  • Open the compartment and push it to the left to unlock. Fold the compartment down and remove it
  • In right-hand drive vehicles, the fuse box is located behind a cover in the glovebox. Open the glovebox, then open the cover and fold it down.
locatie panou sigurante bord Astra J
locatie panou sigurante bord Astra J volan dreapta
tablou sigurante bord Astra J cu diagrama si tabel
1 Displays
2 2009-2012: Exterior lights
2013+: Exterior lights/Body control module
3 2009-2012: Exterior lights
4 2009-2012: Radio
2013+: Infotainment system
5 2009-2013: Infotainment system
2014+: Infotainment system/Instrument
6 2009-2012: Power outlet front
2013+: Power outlet/Cigarette lighter
7 2009-2012: Power outlet rear seat
2013+: Power outlet
8 2009-2012: Left low beam
2013+: Left low beam/Body control module
9 2009-2012: Right low beam
2013+: Right low beam/Body control module/Airbag module
10 2009-2012: Door locks
2013+: Door locks/Body control module
11 Interior fan
12 -
13 -
14 Diagnostic connector
15 Airbag
16 2009-2012: empty slot
2013+: Power outlet
17 Air conditioning system
18 2009-2011: empty slot
2012: Prefuse: radio, Infotainment, displays
2013+: Logistics
19 2009-2012: Brake lights, tail lights, interior lights
2013+: Body control module
20 2009-2012: empty slot
21 2009-2011: Instrument
2012-2013: -
2013+: Instrument panel cluster/Antitheft alarm system
22 Ignition switch/sensor
23 Body control unit
24 Body control unit
25 -
26 2009-2011: empty slot
2012+: Power outlet load compartment (if no load compartment fuse box) (Sports tourer only)
Load compartment fuse box
  • The fuse box is on the left side of the load compartment behind a cover. Remove the cover.
locatie panou sigurante portbagaj Astra J hatchback
locatie panou sigurante portbagaj Astra J combi sports tourer
capac sigurante portbagaj Astra J combi sports tourer
inchidere capac sigurante portbagaj Astra J combi sports tourer
tablou sigurante portbagaj Astra J cu diagrama si tabel
1 2009-2012: Trailer module
2013+: emtpy slot
2 Trailer outlet
3 Parking assist
7 2009-2012: empty slot
2013+: Power seat
8 2009-2012: Anti-theft alarm system
2013+: empty slot
11 Trailer module, Trailer socket
12 2009-2012: empty slot
2013+: Trailer module
13 Trailer outlet
14 2009-2012: empty slot
2013+: Rear seat/Electrical folding
15 -
2013+: Interior mirror/Rear view camera
17 2009-2012: empty slot
2013+: Power outlet
18 -
19 Steering wheel heating
20 Sunroof
21 Heated front seats
22 -
23 -
25 -
26 2009-2014: empty slot
2015+: Deactivated logistic mode
27 -
29 -
30 -
31 Amplifier, Subwoofer
32 Active damping system, Lane departure warning
