sigurante Astra H (2004 - 2010)
Vauxhall Astra H (2004 - 2010) fuses
Înapoi la 🇷🇴 Opel Astra H
Sigurante Astra G (1998 - 2004) Sigurante Astra J (2009 - 2015)
  • The vehicle has two fuse boxes: one behind a cover on the left side of the load compartment and one in the front left of the engine compartment.
  • Depending on trim level, there are two types of fuxe bosex: version A and version B (see images below).
Cigarette lighter fuse location
localizare siguranta bricheta la Opel Astra H
29 For vehicles equipped with version B circuit: fuse no. 29 from the luggage compartment fusebox 15 A
36 For vehicles equipped with version A circuit: fuse no. 36 from the engine compartment fusebox 15 A
Load compartment fuse box (version A)
  • Saloon 5-door, Caravan, Van To open, turn both catches with a coin and fold down cover.
  • Saloon 3-door To open, fold the cover upwards.
  • Saloon 4-door To open, twist catch anti-clockwise and fold down cover.
  • Twintop/cabrio: To open, pull the two knobs, remove the clips and fold the cover upwards.
locatie sigurante portbagaj Astra H hatchback
locatie sigurante portbagaj Astra H cabrio twintop
tablou sigurante portbagaj Astra H (varianta A)
tablou sigurante portbagaj Astra H (varianta A) cu diagrama si tabel
1 Fog lights 15 A
3 Load compartment power outlet 15 A
4 Reversing lights 7.5 A
5 Rear power windows 30 A
6 Air conditioning system 10 A
7 Front power windows 30 A
8 Heated exterior mirrors 7.5 A
Load compartment fuse box (version B)
tablou sigurante portbagaj Astra H (varianta B)
tablou sigurante portbagaj Astra H (varianta B) cu diagrama si tabel
1 Front power windows 25 A
3 Instruments 7.5 A
4 Heating, air conditioning system, electronic climate control 5 A
5 Airbags 7.5 A
8 -
11 Heated rear window 25 A
12 Rear window wiper 15 A
13 Parking assist 5 A
14 Heating, air conditioning system 7.5 A
15 -
16 Seat occupancy recognition, Open&Start system 5 A
17 Rain sensor, air quality sensor, tyre pressure monitoring system (TPMS), interior mirror 5 A
18 Instruments, switches 5 A
19 -
20 CDC 10 A
21 Heated exterior mirrors 7.5 A
22 Sunroof 20 A
23 Rear power windows 25 A
24 Diagnostics plug 7.5 A
25 -
26 Electrical foldable exterior mirrors 7.5 A
27 Ultrasonic sensor, anti-theft alarm system 5 A
29 Cigarette lighter, front power outlet 15 A
30 Rear power outlet 15 A
32 -
33 Open&Start system 15 A
34 Sunroof, TwinTop 25 A
35 Rear power outlet 15 A
36 Socket for towing equipment 20 A
37 -
38 Central locking system, terminal 30 25 A
39 Left seat heating 15 A
40 Right seat heating 15 A
41 -
42 -
43 -
44 -
Luggage compartment relays
diagrama relee portbagaj Opel Astra H
1 Rear window heating (K3_X131)
2 Pin 15 (K1_X131)
3 Pin 15a (K2_X131)
Engine compartment fuse box (version A)
  • Insert a screwdriver into the opening as far as it will go and tilt it sideways. Open the cover upwards and remove
  • The Astra TwinTop always has version B.
  • 1) Different ratings depending on engine and equipment level.
locatie sigurante motor Astra H varianta A
tablou sigurante motor Astra H varianta A
tablou sigurante motor Astra H varianta A cu diagrama si tabel
1 ABS 20 A
2 ABS 30 A
3 Interior fan climate control system 30 A
4 Interior fan, heating, air conditioning system 30 A
5 Radiator fan 11) 30 A
40 A
6 Radiator fan 21) 20 A
30 A
40 A
7 Central locking system 20 A
8 Windscreen washer system, tailgate 10 A
9 Heated rear window, heated exterior mirror 30 A
10 Diagnostics plug 7.5 A
11 Instruments 7.5 A
12 Mobile telephone, Infotainment system, display 7.5 A
13 Courtesy light 5 A
14 Windscreen wiper 30 A
15 Windscreen wiper 30 A
16 Horn, ABS, brake light switch, air conditioning system 5 A
17 Diesel fuel filter or
25 A
20 A
18 Starter 25 A
19 -
20 Horn 15 A
21 Engine electronics 20 A
22 Engine electronics 7.5 A
23 Headlight range adjustment 5 A
24 Fuel pump 15 A
25 -
26 Engine electronics 10 A
27 Heating, air conditioning system, air quality sensor 7.5 A
29 Power steering 5 A
30 Engine electronics 10 A
31 Rear window wiper 15 A
32 Brake light switch 5 A
33 Headlight range adjustment, light switch, clutch switch, instrument, driver's door module 5 A
34 Control unit, steering column module 7.5 A
35 Infotainment system 20 A
36 Cigarette lighter, front power outlet 15 A
Engine compartment fuse box (version B)
locatie sigurante motor Astra H varianta B
tablou sigurante motor Astra H varianta B
tablou sigurante motor Astra H varianta B cu diagrama si tabel
1 ABS 20 A
2 ABS 30 A
3 Interior fan electronic climate control 30 A
4 Interior fan heating and air conditioning system 30 A
40 A
30 A
40 A
7 Windscreen washer system 10 A
8 Horn 15 A
9 Headlight washer system 25 A
11 -
12 -
13 Fog light 15 A
16 Control module electronics, Open&Start system, ABS, brake light switch, TwinTop 5 A
17 Diesel fuel filter heating 25 A
18 Starter 25 A
19 Transmission electronics 30 A
20 Air conditioning system 10 A
23 Adaptive forward lighting, headlight range adjustment 10 A
24 Fuel pump 15 A
25 Transmission electronics 15 A
27 Power steering 5 A
28 Transmission electronics 5 A
29 Transmission electronics 7.5 A
31 Adaptive forward fighting, headlight range adjustment 10 A
32 Brake system, air conditioning system, clutch switch 5 A
33 Adaptive forward lighting, headlight range adjustment, light switch 5 A
36 Mobile telephone, Infotainment system, display 7.5 A
Engine compartment relays
diagrama relee compartiment motor Opel Astra H
K1 Radiator fan
K2 Radiator fan
K3 (K7_X125) (with REC) Headlamp washer pump
(K17_X125) (w/out REC) rear window heating
K4 (K16_X125) (with REC) Front fog lights
(K18_X125) (w/out REC) interior lighting
K5 Windshield wiper low/high
K6 Windshield wiper ON/OFF
K7 Fan, interior compartment - AC / heating
K8 (K14_X125) (with REC) Diesel fiter heating
(K8_X125) (w/out REC) AC compressor
K9 Starter
K10 Radiator fan
K11 (K9_X125) (with REC) AC compressor
(K4_X125) (w/out REC) horn sound signal
K12 Engine management controller
K13 Fuel pump
K14 Pin 15
