sigurante Astra G (1998 - 2004)
Vauxhall Astra G (1998 - 2004) fuses
Înapoi la 🇷🇴 Opel Astra G
Sigurante Astra H (2004 - 2010)
  • The fuse box is behind the storage compartment in the instrument panel. Open, squeeze the side panels and pull down. Remove the box.
  • Using a coin or flat screw driver, rotate the four plastic screws. Remove the fuse panel cover.
locatie sigurante Astra G
deschidere bord sigurante Astra G
instructiuni access sigurante Astra G
cleste plastic sigurante Astra G
panou sigurante Astra G
tablou sigurante Astra G
tablou sigurante numerotat
2 Heater/air conditioning (AC) fan, heated seats 30 A
3 Rear window defrost 40 A
6 Low beam (RH), head lamp adjustment 10 A
7 Side/tail lamps (RH), licence plate lamp 10 A
8 High beam (RH) 10 A
9 Head lamp washer pump 30 A
10 Horn 15 A
11 Central locking 20 A
12 Fog lamps (front) 15 A
13 Interior mirror, Digital multifunction display 1998-2000: 7.5 A
2001+: 5 A
14 Windscreen wiper motor, sunroof (coupe) 30 A
15 Electric windows, sunroof, electric door mirrors 1998-2000: 7.5 A
2001+: 5 A
16 Fog lamps (rear) 10 A
17 Electric windows 30 A
18 Head lamp adjustment, automatic transmission (AT) 1998-2000: 7.5 A
2001+: 5 A
19 Radio receiver, CD changer 10 A
20 Electric windows 30 A
21 Ignition switch key hold solenoid (AT), alarm system, audio system 1998-2000: 7.5 A
2001+: 5 A
22 Indicators/hazard warning lamps, digital multifunction display, trip computer, warning lamps 15 A
23 ABS, TC, power steering 10 A
24 Low beam (LH) 10 A
25 Side/tail lamps (LH), licence plate lamp 10 A
26 High beam (LH) 10 A
27 -
28 Interior lamp 1998-2000: 7.5 A
2001+: 5 A
29 Indicators/hazard warning lamps, interior lamp, automatic transmission (AT) 10 A
30 Sunroof 30 A
31 Rear screen wiper 20 A
32 Daytime running lamps, alarm system 10 A
33 Trailer socket - terminal 30 20 A
34 Audio system, digital multifunction display 20 A
35 Automatic transmission (AT), engine coolant blower motor control module, air conditioning (AC) 10 A
36 cigarette lighter 20 A
37 Heated seats, cruise control, stop lamps 20 A
38 Stop lamps, automatic transmission (AT), digital multifunction display, cruise control 10 A
39 Automatic transmission (AT), engine coolant blower motor control module, air conditioning (AC) 1998-2000: 7.5 A
2001+: 5 A
40 Engine coolant blower motor control module, air conditioning (AC) 1998-2000: 7.5 A
2001+: 5 A
41 Heated door mirror 10 A
42 Seat occupation sensor, interior lamp 5 A
43 Headlamp xenon (RH)
44 Headlamp xenon (LH)
45 Heated seats 5 A
46 Engine management 15 A
47 Auxiliary heater-Diesel 20 A
48 Convertible top 5 A
49 -
50 Engine coolant blower motor-2,0 Diesel/1,7 Diesel with AC 40 A
Driver side (or passanger side for RHD) relay fuse box
explicatie relee bord Astra G
0 empty
R1 Horn relay
R2 Headlamp high beam relay
R3 Rear screen wiper relay
R4 Door mirror heater relay
R5 Fog lamps relay (front)
R6 Fog lamps relay (rear)
R7 Indicator relay (RH)
R8 Indicator relay (LH)
R9 Telephone audiosignal transmitter
R10 Signal converter module - Vehicle speed
R11 empty or n/a
R12 Windscreen wiper motor relay
R13 Heated rear window relay
Engine compartment fuse + relay box (LH)
diagrama relee sigurante motor Astra G
diagrama relee sigurante motor Astra G full cu tabel
1 Ignition switch (empty on some models) 60 A
2 Lights switch/Lights fuse plate 60 A
3 Fuse plate: 3, 9, 17, 19, 20, 28, 30, 33, 34, 41 60 A
4 Engine coolant blower motors 30 A (40 A for vehicles with air conditioning (AC)) 20-40 A
5 ESP (or ABS on some models) 60 A
6 Engine management 20 A
7 Power steering 80 A
8 Engine functions (or Engine coolant blower motors on some models) 40 A
R1 -
R2 1998-2000: X16SZR, X18XE, X20XEV: Engine coolant blower motor relay;
2001+: Engine coolant blower motor relay (except Z12XE);
Filter preheating (diesel)
R3 1998-2000: X14XE, X16XEL, Z16XE: Engine coolant blower motor relay;
X12XE: Injectors;
2001+: Fuel pump relay (except Z20LET/Z22SE)
R4 Fuel pump relay (petrol engines);
Y17DT: Engine control unit
R5 1998-2000: -
2001+: Engine coolant pump relay
R6 1998-2000: Engine management (diesel engines);
2001+: Engine coolant blower motor;
Y17DT: spill valve
R7 Headlamps washer pump
R8 -
Engine compartment relay box (RH)
relee dreapta motor Astra G
R1 Fan
R2 Alarm horn
