Revizie Opel Vectra A (1988 - 1995)
Revizie ulei Vectra B (1995 - 2002)
Cât ulei intră? Capacități ulei de motor Opel Vectra A
14NV
1.4
3,00 L 15.000 km / 12 luni
17
1.7 D
4,75 L 7.500 km / 12 luni
17DT
1.7 TD
4,50 L 7.500 km / 12 luni
20SEH
2.0i
4,00 L 15.000 km / 12 luni
20SEH
2.0i 4x4
20XE
2000 16V
4,50 L 15.000 km / 12 luni
20XE
2000 16V 4x4
C16NZ
1.6i
3,50 L 15.000 km / 12 luni
C18NZ
1.8i
C20LET
2.0i 16V Turbo 4x4
C25XE
2.5i V6
E18NVR
1.8S
E18NVR
1.8S 4x4
X20XEV
2.0 16v 100 kW (136 CP)
4,00 L 15.000 km / 12 luni Unele surse mentioneaza 4,25 L
Multigrad; API SG/CD
De la SAE 10W-40 la 20W-50
Selectați modelul
5W-50 10W-40 5W-40 0W-40 15W-40 10W-60 20W-50 5W-30 0W-30 15W-50
Se calculeaza...
Mobil 1<small>™</small> FS X2 5W-50
Mobil Super 2000 X1 10W-40
Mobil Super 3000 X1 5W-40
Mobil 1<small>™</small> FS 0W-40
GM Semi Synthetic 10W-40
Shell Helix HX5 15W-40
Castrol GTX 15W-40
Castrol GTX Ultraclean 10W-40
Castrol Magnatec 10W-40
Castrol Magnatec A3/B4 5W-40
Castrol Edge 10W-60
Castrol Edge 0W-40
Castrol Edge 5W-40
Liqui Moly MoS2 Low-Friction 20W-50
Liqui Moly MOS2 15W-40
Liqui Moly Touring High Tech 15W-40
Liqui Moly Leichtlauf cu MOS2 10W-40
Liqui Moly Leichtlauf 10W-40
Liqui Moly Molygen New Generation 10W-40
Liqui Moly Molygen 5W-50
Liqui Moly Synthoil High Tech 5W-40
Liqui Moly Leichtlauf High Tech 5W-40
Liqui Moly Special Tec LL 5W-30
Liqui Moly Synthoil Longtime 0W-30
Liqui Moly Synthoil Energy 0W-40
Motul 4100 Power 15W-50
Motul 4000 Motion 15W-40
Motul 6100 Synergie+ 10W-40
Motul 8100 X-CESS 5W-40
Motul 8100 X-CESS GEN2 5W-40
Aral BlueTronic II 10W-40
Aral HighTronic 5W-40
Fuchs Titan Formula 15W-40
Fuchs Titan Supersyn LONGLIFE 5W-40
Mannol Extreme 7915 5W-40
Ravenol LLO 10W-40
Ravenol VST 5W-40
Total Quartz Energy 7000 10W-40
Total Quartz Energy 9000 5W-40
Total Quartz Ineo MDC 5W-30
Arată toate
