vipvalentin_braila- Suspendat
- 7 mesaje
- din 15 Mai 2019
- Astra 2007
- Braila
vipvalentin_braila- Mesaje scrise: 7
- Masina: Astra 2007
- Cont inregistrat: 15 Mai 2019
Salutare! Am si eu un gtc benzina turbo 2.0 Lel 170 cai si imi apare martorul Check engine in bord cand turez mai tare intr o depasire COD:P1106 Boost Pressure Sensor Circuit Range/Performance B-018 ! De la ce poate fii ? Am schimbat senzorul presiune turbo MAP si degeaba.Ma confrunt cu aceasta problema de 4 ani , nimeni nu i-a dat de cap, Ajutor!
MODEL: Astra 2006
MOTOR: 2.0 benzina LEL
MODEL: Astra 2006
- corsablue
- 2,584 mesaje
- din 18 Feb 2008
- Corsa 2005 Z13DT
corsablue
- Mesaje scrise: 2,584
- Masina: Corsa 2005 Z13DT
Uite ce zic polacii :
https://www.auto-krak.pl/aut...lad-tdc-p1106-11/
Cu un minim efort aflai singur...
Edit Mr.Opel:
Edit Mr.Opel:
Cause: Incorrectly installed atmospheric pressure sensor (Bosch no.: 261 002 137 instead of 261 230 009). Due to the different characteristics of the two sensors, it indicates an incorrect pressure of approximately 0.47 bar (47kPa) instead of the actual ambient air pressure, which causes boost pressure restrictions and DTC error P1106 (11).
Solution: To check the problem, first check the atmospheric pressure in the Tech 2 datalist (values available from TIS 2000-DVD, version 74). If the wrong sensor is installed, install the correct one with numbers - GM No.: 9117763 / Catalog No.: 62 38 084 (Bosch No.: 261 230 009).
- bibu16v
- 6,567 mesaje
- din 25 Jan 2016
- Astra 1995 X16XEL
bibu16v
- Mesaje scrise: 6,567
- Masina: Astra 1995 X16XEL
- 7 mesaje
- din 15 Mai 2019
- Astra 2007
- Braila
- corsablue
- 2,584 mesaje
- din 18 Feb 2008
- Corsa 2005 Z13DT
corsablue
- 7 mesaje
- din 15 Mai 2019
- Astra 2007
- Braila
- DRosiuoru
- 382 mesaje
- din 08 Mar 2022
- Insignia 2010 A20DTH
- Arad
DRosiuoru
- Mesaje scrise: 382
- Cont inregistrat: 08 Mar 2022
Pune un tester pe masina si verifica la valori in timp real valorile de la presiunea atmosferica si presiunea turbo din admisie ( MAP ) . La ultima compara valoare ceruta ( de ECU ) si valoarea reala pe care o citeste senzorul MAP la simularea conditiilor in care apare eroarea . Daca la valori apar diferente ai un punct de plecare . Presiunea atmosferica ( barometrica ) trebuie sa fie cat mai aproape de 1 BAR la relanti .
Ultima modificare facuta de DRosiuoru la Mar 21 Nov, 2023 7:27 pm
- mariocove
- 321 mesaje
- din 08 Dec 2008
- Vectra 2007 Z18XER
mariocove
- Mesaje scrise: 321
- Masina: Vectra 2007 Z18XER
- Cont inregistrat: 08 Dec 2008
- 7 mesaje
- din 15 Mai 2019
- Astra 2007
- Braila
- Mr.Opel
- Admin
- 2,297 mesaje
- din 15 Apr 2004
- Astra 2001 Y17DT
- Mures
Mr.Opel
- Mesaje scrise: 2,297
- Masina: Astra 2001 Y17DT
- Cont inregistrat: 15 Apr 2004
- bibu16v
- 6,567 mesaje
- din 25 Jan 2016
- Astra 1995 X16XEL
bibu16v
